Internal USB Solution
Go to solution Solved by Norman_the_Owl,
Delid a USB hub or something and use that, it's really your only choice.
Hi Everybody
Im currently in the process of doing a retro console gaming case mod on the case i used for my very first build many a year ago. Im having trouble thinking of a solution for running the controller adapters for the original controllers (gamecube/N64/SNES/Sega/Playstation/Atari). These all come as USB adapters for external use but im looking at mounting them in the front panel and dont want to run usb cables through the back of my case to plug in externally. Can anybody think of another way to do this? Are there any products out there that will allow me to run about 6 usbs from a single header?
thanks in advance
Sonny
IF AT FIRST YOU DON'T SUCCEED, GET A BIGGER HAMMER
https://linustechtips.com/topic/232854-internal-usb-solution/
Each internal USB header only supports 2 USB ports. This goes for both USB2 and USB3, so to have 6 USB ports you would need 3 USB headers on your motherboard. You can use a USB hub to plug multiple devices into a single USB port, but this might cause issues depending on what devices and how many you are trying to connect.
You can easily buy a small adapter fro USB2 header to USB2 ports like this one (they are also available for USB3):
http://www.scan.co.uk/products/lycom-usb-20-adaptor-header-%28female%29-to-2x-type-a-%28male%29-ideal-for-motherboards
"PSU brands are meaningless, look up the OEM."
https://linustechtips.com/topic/232854-internal-usb-solution/#findComment-3182561
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
https://linustechtips.com/topic/232854-internal-usb-solution/#findComment-3182760
So if i delid a USB hub and then mount it to the drive cage that should keep it looking tidy inside and only have a single cable to route?
https://linustechtips.com/topic/232854-internal-usb-solution/#findComment-3182856
