Strange Buzzing Noise
Solved by Boink,
This may not be something to worry about but I would rather go through some troubleshooting than risk several hundred dollars in hardware. Better safe than sorry. (and broke)
First, check your fans. They most likely aren't the culprit but it never hurts to check.
Then, once you've ruled out the fans, take out the graphics card and load something up on the iGPU. If that doesn't work try testing the RAM sticks, one at a time, or relocating your RAM to different slots. If neither work you may have a problem with your motherboard.
Whichever ends up being the problem part can easily be sent for RMA and replaced within a few days.
