best monitor for movies ?
i_d7s
Im looking for a good 27" 1440p monitor , and i'm not in Interested in gaming :)
I only need good and sharp image
Should i get PLS or IPS
I found X-STAR DP2710 , any Other suggestions ?
My budget is about $200 to $350.
Thanks.
Thanks.
I can not find a 1440p 27" monitor for this budget. (I looked on newegg)
Written on my Lenovo Z500 T - I5-3230M   Or
My pc :)
Thanks.
asus pg278q  not the swift though
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
This Acer comes in at $400. I'm not sure you're going to find anything worthwhile under $350 for a 1440p monitor.
The ASUS PB278Q is $460 and would be my choice in the category of 1440p non-gaming non-ultrawide monitors.
Fractal Design Arc Midi R2 | ASUS Z97-A | Intel Core i5 4690K | G.Skill Ripjaw 4 GB (desperately needs upgrade) | MSI Radeon R9 290 | EVGA SuperNOVA 750 G2 | Samsung 840 EVO 250 GB SSD | Seagate Constellation 1 TB HDD (also needs upgrade) | NZXT Kraken X61 for CPU | NZXT Kraken X61 + G10 for GPU | Corsair M45 | CM Storm Quickfire TK | ASUS Xonar DSX | Denon AD-H2000
Not even for $400 ! :(
See my post above listing the Acer monitor for $400.
You originally specified 200-350 dollars
My pc :)
Cheapest reputable* brand 27" 1440p monitor i could find on newegg:
nvm was only 1080p
* You can pay a lot less but they are brands like QNIX or wasabi mango that I've never heard of.
Just go onto newegg.com and search 27" 1440p monitor
My pc :)
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009626&cm_re=27%22_1440p_monitor-_-24-009-626-_-Product
The Acer monitor you listed is 1080p not 1440p.
Oops sorry, got rid of it.
My pc :)
Would you say the asus is better the benq pt display and the dell 2713hm?
I'm still using an ASUS 24" 1080p monitor that's about 6 years old and every experience I've had with the company has been nothing short of fantastic. I can't say anything specific about those monitors since I haven't used them before but I would generally go with ASUS over Dell or Acer, yes.
