I keep changing my mind a ton and I'm not sure which build to get. I know build two is the better one for my needs (gaming, video editing/content creation, graphic design and streaming) but I really like the sound of build one.
Which one do you think I should get? There is a possibility of me adding another 980 in a year to build one, but that's a 50/50.
Build one
Build two
https://linustechtips.com/topic/231703-which-parts-list/
One, and latter on add a second 980 or who knows new nvidia serie.
The blood on to your heart start pumping faster when you notice me.
But is ok.
Judge me for my nickname, my avatar and for the low amounts of posts I have. I will keep your heart beat raised.
https://linustechtips.com/topic/231703-which-parts-list/#findComment-3167897
I would actually get the second one, because the performance increase for gaming will be a lot higher than getting a faster cpu
I'm sure he does more work than gaming, and the games would perform the same in both cpu's. Look at the work he does. There is a difference that he will notice, with a 6core 15mb and 8 core 20mb.
But is ok.
https://linustechtips.com/topic/231703-which-parts-list/#findComment-3167905
I would go for the first one and add another GTX 980 later because you better spend more for the amazing performance in rendering of the 5960X and keep that CPU for over 5 years without problems. Get the H105 for better cooling performance if there is enough fan connectors on your motherboard. Don't get G.Skills memory, get Corsair Dominator Platinum for way better performance in rendering. Get an Asus motherboard. I presume you were planing to use the 2 TB to install your games so get a Seagate SSHD instead of the Barracuda for way better performance in every way. Samsung EVO SSDs are kind of weak for RANDOM READ and WRITE, I would spend a bit more for a 850 PRO version. And I would go with a Corsair RM power supply.
PC : | CPU: Intel 4790K | COOLER: Corsair H105 w/ JetFlo's Push/Pull | MOBO: EVGA Z97 Classified | GPU: EVGA FTW 4GB GTX 970 X2 | RAM: Kingston HyperX Beast 1866Mhz 32GB | CASE: HAF Stacker 945 | PSU: Corsair AX1500i | DISPLAY: Asus MX299Q | SSD: 2 X Corsair Neutron GTX 480 GB in RAID0 | mSATA SSD: Samsung 840 EVO 500 GB | HDD: 4 X Western Digital RED 4 TB in JBOD |
https://linustechtips.com/topic/231703-which-parts-list/#findComment-3167949
true, but it depends how serious he is about it
https://linustechtips.com/topic/231703-which-parts-list/#findComment-3167960
Changed the CPU cooler to a H105, and I am pretty sure I read a thread 20mins ago with people recommending EVGA Gold PSUs over the Corsair RMs.
Corsair Dominator Platinums are ridiculously expensive at DD4 - they're double the price of the G.skills, so unless there is 2x better performance I probably won't get them. Also, would you recommend just a 2TB SSHD (is this one alright?) instead of the HDD and SSD? I really haven't looked into SSHDS.
https://linustechtips.com/topic/231703-which-parts-list/#findComment-3168030
no, get a seperate ssd possibly the 850pro and any 2tb hard drive in the sshd you only have 8gb of ssd cache compared to having your whole OS on it
https://linustechtips.com/topic/231703-which-parts-list/#findComment-3168054
