-snip-
As @iamthecpu said model of mouse please. Try it on another computer laptop and see if the same issue happens. If it only double clicks on your computer try to reinstall drivers etc.
Gaming Rig - Excalibur - CPU: i5 6600k @ 4.1GHz, CPU Cooler: Hyper 212 Evo, Mobo: MSI Gaming M3 RAM: 16GB Corsair @2400MHz, GPU: EVGA 1060, Case: NZXT Phantom Full Tower (Red)
My Virtualization Server - Dell R710: 2x X5570s @ 2.93GHz with 32GB DDR3 RAM [Web Server, OSX, Plex, Reverse Proxy]
I love computers, gaming, coding, and photography! Be sure to quote me so I can respond to your post!
https://linustechtips.com/topic/231626-need-help/#findComment-3167052
My mouse keep on double clicking when i only single click....
Is this program problem or mouse problem..i just only bought the mouse 2 weeks ago
And its wireless
Is a virus made by Google, you get it mostly on verry old mouse or cheap opticals one, mostly from porn sites. Use SpyBot, Hitman Pro, MalwareBytes, In some cases It wont help cuz it sticked, so best thing is to buy new more new one, laser mouse. Get a good antivirus, add adblock and adblock plus to chrome, or add adblock to mozilla firefox and watch the porn trough mozilla in some safe sites. (like if I helped)
The blood on to your heart start pumping faster when you notice me.
But is ok.
Judge me for my nickname, my avatar and for the low amounts of posts I have. I will keep your heart beat raised.
https://linustechtips.com/topic/231626-need-help/#findComment-3167063
Test it with another mice.
Wireless mice/keyboards are known to have some reliability issues.
Like for me, there is a tad delay when the mice was just sitting on my desk for about 20 seconds.
Mine does this because of as a power conserving feature however, I think you're experiencing a reliability issue.
Try RMAing it, or return it and get a new one.
#SAMSUNG  "provided us 4 1tb ssds so we could run the whole site off solid state." - LinusTech
#GALAXY
#ATIV
https://linustechtips.com/topic/231626-need-help/#findComment-3167087
there's an adware known as doubleclick.exe or something malware , do a full sweep of the system partition with a basic AV Software to check that , in other case it might be that there's something stuck between the mice button spring & is causing the issue & on other issue the mice itself is damaged or there's a faulty USB port (one that you're currently using) try changing the ports in that case..
Hope this helps..
Details separate people.
https://linustechtips.com/topic/231626-need-help/#findComment-3167115
