So my current GPU just broke so i have to use my old amd 5750.. When i try to install the amd catalyst drivers i get an error (Failed to load detection driver) i have tried using a older verision of amd catalyst but i just get the same error. Does anyone have any clue why im getting this error message?
https://linustechtips.com/topic/231375-amd-catalyst-problem/
what was your old card if it was nvidia you have to wipe those drivers
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/231375-amd-catalyst-problem/#findComment-3163632
AMD site is currently down for maintenance so you won't be able to download drivers at the moment which is really sad for me since I just did a clean install.
Edit : turns out you can just not via the homepage, I've been off today, a week or so ago they were doing broader maintenance where you just couldn't download any drivers.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
https://linustechtips.com/topic/231375-amd-catalyst-problem/#findComment-3163667
