I have an HP Pavilion Laptop. While charging an Orange indicator appears on the side and it turns to white when fully charged. Now even after disconnecting charger the white light remains there. By plugging in charger but with no power connected the light goes off and when power is on the light comes again but orange. I currently have the laptop turned off with charger removed and white light is back. While working on battery in Windows it shows Plugged in and Not Charging. Why does it show plugged in when it is completely unplugged ? I tried reinserting battery. When battery is removed no light and when inserted back white comes again. What to do now ? Sorry for the long thread. Thanks.
| CPU: Intel Core i5 8400 | Motherboard: MSI Z370 PC Pro | CPU Cooler: CM Hyper 212 PLUS | GPU: Zotac GeForce GTX 1070 AMP! Edition | RAM: G.Skill Aegis 16GB DDR4 2400 MHz | PSU: Corsair VS650 | SSD: SanDisk SSD Plus 120GB | HDD: Seagate Barracuda 2TB | Monitor: Dell S2240L | OS: Windows 10 Pro x64 |
https://linustechtips.com/topic/231099-laptop-charging-light/
Not too much of an issue if your laptop still charges, definetely something to contact HP about.
Asus B85M-G / Intel i5-4670 / Sapphire 290X Tri-X / 16GB RAM (Corsair Value 1x8GB + Crucial 2x4GB) @1333MHz / Coolermaster B600 (600W) / Be Quiet! Silent Base 800 / Adata SP900 128GB SSD & WD Green 2TB & SG Barracuda 1TB / Dell AT-101W / Logitech G502 / Acer G226HQL & X-Star DP2710LED
https://linustechtips.com/topic/231099-laptop-charging-light/#findComment-3160998
