FX 9590 temps
Go to solution Solved by Lord Pantaloons,
Safe temps for AMD CPU's is no more than 62c for extended periods, AMD GPU's are designed to run up to 95c.
-The Bellerophon- Obsidian 550D-i5-3570k@4.5Ghz -Asus Sabertooth Z77-16GB Corsair Dominator Platinum 1866Mhz-x2 EVGA GTX 760 Dual FTW 4GB-Creative Sound Blaster XF-i Titanium-OCZ Vertex Plus 120GB-Seagate Barracuda 2TB- https://linustechtips.com/main/topic/60154-the-not-really-a-build-log-build-log/ Twofold http://linustechtips.com/main/topic/121043-twofold-a-dual-itx-system/ How great is EVGA? http://linustechtips.com/main/topic/110662-evga-how-great-are-they/#entry1478299
https://linustechtips.com/topic/230614-fx-9590-temps/#findComment-3155686
The max safe prolonged operating temp is 62C I believe (I may be wrong). Just FYI, the 9590 doesn't have have much overclocking headroom if at all, the  9590 is already at its near limits. It's a highly binned and OC'ed 8350. Make sure to get a good cooler with it, because you'll need it.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/230614-fx-9590-temps/#findComment-3155689
I think you should clarify that only the R9 290 series are designed to go to 95C.
EDIT: But the OP did specifically ask about the 295X2, so nevermind.
https://linustechtips.com/topic/230614-fx-9590-temps/#findComment-3155701
I should have specified about the 290/290x chips but I didn't think about it since the OP was just asking about the 295x2 thanks for adding that but on though.
https://linustechtips.com/topic/230614-fx-9590-temps/#findComment-3155709
