Max Temp
Go to solution Solved by airdeano,
water temperature to not exceed 50°C
CPU temperature is not water temperature.
airdeano
I've noticed most pumps/res/tubings etc say their max temp is around 50-60*C.  Does that mean getting my I7-2600K @ 5.0GHz is gonna be difficult?  I barely hit 70*C @ 4.5GHz on air.
Specs: Core I7-2600K @ 4.5GHz @ 1.35V, 4x4GB Corsair Vengeance Black 1600MHz CL9, Cooler Master Evo 212, MSI Z77 Mpower Motherboard, Sapphire Radeon HD 7950 Vapor-X @ 1000/1400, Cooler Master HAF 932 Blue Edition w/ 3 Cougar Hydraulic Bearing 120MM fans (2 up top 1 in the bottom) replaced side panel with a window, and rear fan with a Cougar Hydraulic Bearing 140MM, Cooler Master GX 650 80+ Bronze PSU, Samsung DVD-RW, Samsung 840 Pro 128GB SSD, Seagate 750GB SATA III 7200RPM
https://linustechtips.com/topic/23039-max-temp/
