Metro last light same fps any resolution/quality? [RESOLVED]
Pacc
Hello there, picked up metro last light a while back and i have this problem...
When playing the game i get like from 30 fps when starting the game to 4fps after 20 seconds. The menu plays alright and the fps does not change no matter what i do with the video settings.
What could it be?
I know your mailbox...
What are your specs?
Most likely the problem is the Physx in the game. Try disabeling it.
Processor: i7 4770k (watercooled with h60v2)
GPU: XFX 280X
RAM: Corsair dominator platinum 1866Mhz 16 GB
rest i believe are irrelevant.
How do i disable it?
Probably PhysX or SSAA, the Metro Redux games defaulted to 4x SSAA for me for some reason.
GPU: XFX 280X
In the in game menu, under ´Game options´ (or something similar). There should be a box titled ´Advanced PhysX´. Uncheck that box.
Also check the SSAA as the others have suggested.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
I had the same problem.
To fix this, simply allocated 7GB (or 5GB if you have only 8GB installed) to the game and that'll fix it. This also works for the redux edition.
Samung Tab S 8.4
Thanks!
Worked :)
