I am planning on overclocking my system I have a coolermaster haf 932 GA-Z87X-OC Force i7-4770k gtx 780. I want to overclock my CPU and GPU the 780 has the reference cooler on it. What kind of parts will I need like the fittings tubes resivours etc. here is a complete list of parts in my computer.
Coolermaster haf 932
I7-4770k
Gtx-780(reference cooler)
Gigabyte GA-Z87X-OC Force
XFX Core Edition PRO850W
CORSAIR Vengeance 8GB (2 x 4GB)
HP 2511x 25-inch
Seagate barracuda 1tb
As of now I have all stock cooling solutions
https://linustechtips.com/topic/22997-first-water-cooling-system/
You can do custom(open), but if this rig will be moved around, I'd go with closed. It'll be much lighter.
https://linustechtips.com/topic/22997-first-water-cooling-system/#findComment-291022
usually any water-cooling loop is a closed system. they all have a cap to prevent dust
and debris from entering the system.
i think you mean sealed (closed - AIO) or custom loop.
overclocking is a heat generator, so water-cooling is prolly the best advantage to use
to lower the temperatures and allow a quieter operation to exist.
it is also the most expensive to get into.
you'll want to research how much radiator you'll need to have to cool a 4770k/780
overclocked and deal with that first. then what case can hold all of that equipment without
looking terrible messy and unpleasing to look at.
you'll prolly find that this will start at $400+ to get started just for the cooling components
and prolly more depending on what stage of aesthetics you would like to have.
airdeano
https://linustechtips.com/topic/22997-first-water-cooling-system/#findComment-291136
the reviews are not even out yet completely for the haswell release as
of saturday. so you'll prolly have to wait like the rest of us to find out
how hot this overclocking can get.
from preliminary releases suggest that it is going to be hotter than ivey
bridge was so with that said, be prepared to shell a budget quickly.
airdeano
https://linustechtips.com/topic/22997-first-water-cooling-system/#findComment-291267
