Hello I am currently in the process of building a new computer but I'm stuck at the fans.
The case I am getting is the Corsair Obsidian 750D and I want to kit it out with Noctua fans, 5 NF-A14's, 2 NF-F12's and NH-D15 for the cpu cooler but with all these fans the ASRock 990FX Extreme9 cannot support all these fans so I thought the Grid + would work but before I buy anything I want to ask the LTT community first.
How can I have all the fans powered and able to be controlled?
Thanks hope this is enough information for you to help me.
https://linustechtips.com/topic/229430-need-a-fan-controller/
Just buy Apple. They control their fans very very well.
But actually I've heard good things about the NZXT Sentry.
EDIT: maybe I should read the damn post first. Yes you will be able to do everything you asked AFAIK but Ive also heard that Grid isn't great.
EDIT #2: I think I'm illiterate know. Listen to everybody below me.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/229430-need-a-fan-controller/#findComment-3140217
You can control the fan speeds using NZXT CAM.
Also, I don't think NF-A12's exist..
https://linustechtips.com/topic/229430-need-a-fan-controller/#findComment-3140222
I just looked at the Sentry 2 and I think I can do it by using 2 of the Motherboard headers and the controller.
EDIT: But the problem with that is the Sentry is 3 pin and all the fans are 4 pin
https://linustechtips.com/topic/229430-need-a-fan-controller/#findComment-3140260
Yeah just noticed that typo I meant NF-F12, Not that good at proof reading.
I don't think there are any 3pin NF-F12's. 4pin connectors don't physically fit into the Grid+.
https://linustechtips.com/topic/229430-need-a-fan-controller/#findComment-3140264
