Personal preference really, the CPU will shut itself down if it reaches a critical temp. I obey my 85C rule unless I'm feeling particularly crazy about hitting a cinebench score.
Last 4690k had it maxing at 83C under AIDA64 @1.29v
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
max 80-85C for 24/7 use.
80c max is my comfort zone.
i7 7700k @ 4.9ghz | Asus Maximus IX Hero | G.skill 32gb @ 3200 | Gtx 1080 classified | In win 909 | Samsung 960 pro 1tb | WD caviar blue 1tb x3 | Dell u3417w | Corsair H115i | Ducky premier dk9008p (mx reds) | Logitech g900 | Sennheiser hd 800s w/ hdvd 800 | Audioengine a5+ w/ s8
85° under synthetic stress testing (in manual voltage mode) as normal real-world
usage will not lean on the CPU like the synthetic tests do. so striving for maximum
overclock to say 85° (in manual voltage mode) and then when stable, revert to
adaptive voltage mode and your temps for normal use will be very conservative.
this would be for advanced cooling methods than just the stock CPU cooler.
