How Much power would i need in order to run a 3930k and 2 titans Water cooled with something like 12 fans, 3 HDDs, quite a number of USB devices, and some lights? i want to know what kind of wattage i would be looking at here. please and thank you!
you would probably want around 1000w psu, i would get a 1200 watt so your not pushing it though, if you overclocked the 3930k youll want a good beefy psu
https://linustechtips.com/topic/22934-how-much-power/#findComment-290081
The AX1200i looks likea good buy, bit pricey but if u have 2 titans, then probably won't be to u
CPU: Ryzen 5 3600 | Cooler: Stock | RAM: 16GB Hyper Fury X RGB | GPU: RTX 2080 Super FTW3 | Motherboard: Gigabyte Aorus Elite| PSU: Corsair RM850x
Storage: WD SN750 500GB / 850 500GB Samsung Evo /  | CASE: 570X | Display: Dell u2414h  | KEYBOARD: Corsair K70 | MOUSE: Corsair M65
https://linustechtips.com/topic/22934-how-much-power/#findComment-290153
The Corsair AX850 or the Seasonic X850 are good choices for your psu.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/22934-how-much-power/#findComment-290681
