So I downloaded CPU-Z in my old PC and it says my memory speed is only 400 Mhz
My processor is a Core2 Duo E2180 and my motherboard is Asus P5G41T-M LX3, shouldn't I be able to crack it up a bit?
Core2 Quad Q9400 @ 3.00GHz ✦  8GB Corsair RAM ✦Asus P5G41Tm - Lx3 ✦ Sapphire R9 270 Dual-X ✦ WD Caviar Green 640 GB ✦ Seagate Barracuda 160GB ✦ Fractal Design Define R5 ✦ 1Life ps:jet 700W ✦
Lenovo Y520 - GTX1050Ti - i77700k - 250GB Samsung M.2 NVME SSD  :D
https://linustechtips.com/topic/229243-ram-speed/
that motherboard should be able to support up to 8GB of 1066MHz ram.
so yes you should be able to crank it up a lot
How do Reavers clean their spears?
|Specs in profile|
The Wheel of Time turns, and Ages come and pass, leaving memories that become legend. Legend fades to myth, and even myth is long forgotten when the Age that gave it birth comes again.
https://linustechtips.com/topic/229243-ram-speed/#findComment-3137485
You speed is registering at 400MHz because, DDR stands for Double Data Rate. So, you have to double the reported speed to get the effective speed. It looks like your RAM is operating correctly for 800MHz DDR3. You could overclock but memory speed has little affect in everyday use outside a few specific programs. Also for older hardware like yours, the low latency 6-6-6-15, of your RAM has more of a benefit than the higher bandwidth that would come from increasing the speed. More than likely if you overclocked the speed you would have to loosen the timings.
https://linustechtips.com/topic/229243-ram-speed/#findComment-3137499
Its only running in single channel. So its 400 MHz not 800
Aslo this was the first of the DDR3 boards and its 775 socket. It will not run as fast as newer DDR3 boards will. But the board shoould do dual channel if ihe configures it correctly
Read the motherboard manual
https://linustechtips.com/topic/229243-ram-speed/#findComment-3138286
It is still running at 800MHz, DDR and dual channel are two different things, even with one slot occupied it will still be double data rate. The data rate is determined by the memory type; the motherboard, number of sticks or anything else does not affect this. If he had two sticks then it would be dual channel and more bandwidth would be available to the CPU, but it does not affect the speed or data rate of the modules themselves. Think of dual channel like RAID 0 with two drives, not totally the same thing but close enough.
Again, with hardware of the era timings are more important than speed. Also with that CPU the RAM will not be the bottleneck in the system unless he is using the 4GB up then he would just need to buy more RAM, the CPU is going to be the limiting factor in the build.
https://linustechtips.com/topic/229243-ram-speed/#findComment-3144345
