Question about my cooling loop
Solved by FreezeFlyte,
Yea generally there is not performance difference between push and pull. But if you are using a dense fin array then a static preasure optimized fan will do better. And same goes with a high flow fan in a more open fin array radiator. Good Luck.
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
4
derekchan ·
Posted in New Builds and Planning8 -
1
2
6
5
7
kerriya ·
Posted in Cases and Mods14
play_circle_filled
Latest From ShortCircuit:
