Hey guys im kinda new around here and im not sure if this is already answered but i built my computer in August and use it mostly for gaming.  As i have learned more about computers and stuff i have come to realize that i should have also gotten an SSD.  Now my question is, "can i add in an SSD as a new boot drive, fresh install windows on it, and still keep all my old data on my HDD?" The biggest concern for me is that all my desktop stuff wont remain and that my windows settings will all be reset.  If you guys can help inform me about SSD's and if this idea would even work since i already have my OS on my HDD and have been using it for almost 2 months.  If you guys could also help me find the right size SSD because i play games like BF4, League of Legends, PayDay 2, and will be getting borderlands The Pre-Sequel.  So any help is appreciated :)
My Computer:
Cpu: AMD Fx-8350 (4.2GHz)
Gpu: Radeon R9 270x
Motherboard: GIGABYTE GA-990FXA
Ram: G-Skill 16 GB
Storage: 1TB Seagate barracuda 7200 RPM
OS: Windows 7 64-Bit
https://linustechtips.com/topic/228758-ssd-help/
Linus had a great video about SSD upgrade
Are you new? Please read CoC  Before posting! PLEASE SELECT 'AUTOMATIC' FOR FONT COLOR FOR US DARK THEME USERS (Only for dark shades)If you can read this, it means you need to change to NIGHT THEME (bottom left above LMG logo) Please follow your threads and Quote people when replying to them. Mark your problem as solved if answered. Don't spam, nobody likes a spammer. DO NOT QUOTE IMAGES! BE NICE!
https://linustechtips.com/topic/228758-ssd-help/#findComment-3131098
My Computer:
Gpu: Radeon R9 270x
Ram: G-Skill 16 GB
i would reccomend that you transfer the install and get a 240gb ssd whats your budget
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/228758-ssd-help/#findComment-3131100
https://linustechtips.com/topic/228758-ssd-help/#findComment-3131123
my budget is between 100-200 and i dont mind waiting for like a sale on Newegg or something.  So what are trustworthy brands? and i also heard that cloning the install can leave lots of problems
here you can buy almost two and raid 0 them http://pcpartpicker.com/part/a-data-internal-hard-drive-asp920ss3256gmc if you dont want to do tha then http://pcpartpicker.com/part/samsung-internal-hard-drive-mz7pd256bw  this would be the fastest option
https://linustechtips.com/topic/228758-ssd-help/#findComment-3131162
Yea cloning can cause a lot of issues
Crucial, Samsung, Kingston, intel
https://linustechtips.com/topic/228758-ssd-help/#findComment-3131171
and another question, is the write speed all that important? cuz the crucial ones have about 530 mb/s sequential read but like 300 mb/s sequential write. So is it mostly the read speed that matters?
i would reccomend the previously posted and yes it does matter a lot so i would reccomed going with aspp920 or a sandisk extreme 2 or a samsung 840 pro they are all nice drives
https://linustechtips.com/topic/228758-ssd-help/#findComment-3131432
For $200 you could get a crucial mx100 512gb. Very good value for a very good drive. :)
https://linustechtips.com/topic/228758-ssd-help/#findComment-3132220
okay im looking at drives. and i like the options you have given, but as for the windows question, do i do a fresh install and it will pull all my important info off of my HDD after i boot from the SSD, turn it off, change boot drive to SSD, and then plug in HDD?
and which one is a better choice?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820721108 Kingston v300 240GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147192 Samsung 840 Pro 120GB
https://linustechtips.com/topic/228758-ssd-help/#findComment-3132255
