Hi
i'm planing to build my pc after a lot of saving and gathering
my budget is 3000$ max max max
i did a LOT of search until i decided to do it B)
 here is my parts
pcpartpicker: http://ca.pcpartpicker.com/user/saudivip/saved/1Hgg
cpu : i7-4770k (350$)
mobo : msi z87-gd65 gaming (190$)
gpu : evga gtx 780 acx sc (660$)
cpu cooler : swiftech h220 (150$)
memory : g.skill ripjaws x 16GB (154$)
storage : samsung 840 pro 256GB (242$) & wd black 2TB (190$)
case : cosmos 2 (330$)
psu : SeaSonic 750W 80 PLUS Gold Certified ATX12V / EPS12V Power Supply (160$)
monitor : dell u2713hm (580$)
keyboard : razer blackwidow ultimate 2013 (120$)
mouse : g700s or func ms-3 (79$-76$
total : 3220$
its 3200$ cant i get same/better performance for 3000$
and it will be great to hear your guys suggestions
ill be using this build for designing(3d and stuff) / gaming
sorry if i misspelled any word
https://linustechtips.com/topic/22852-first-awesome-build/
If you get this Eneramx PSU, you'll save money: http://www.newegg.com/Product/Product.aspx?Item=N82E16817194086
It's 750 watts, semi-modular, and has slightly lower efficiency. (Bronze)
https://linustechtips.com/topic/22852-first-awesome-build/#findComment-289050
looking at your component list, there's absolutely no reason why you should get a cosmos 2. the case is gigantic and designed for big water cooling loops and you won't be utilizing any of the advantages of having such a big case.
your case will probably look stupidly empty when you build this rig.
I'd recommend something from corsair like a 650d, or maybe something from fractal design like the Arc Midi R2 or Define R4.
As for the monitor, don't get the dell.
the Asus PB278Q is better in almost every single aspect.
or maybe the Viewsonic VP2770-LED if you spend the extra cash (749 on newegg).
The ViewSonic and the Asus both use PLS panels (newer technology, arguably better than IPS). They both use a light matte (semi-glossy) finish unlike the grainy heavy matte finish on the dell.
Advantages of the viewsonic is the better response time, integrated usb 3.0 hub, does not use PWM Dimming for the brightness of the monitor which might cause dizziness or headaches to some users.
https://linustechtips.com/topic/22852-first-awesome-build/#findComment-290157
is it going to be ugly T_T
ill use some sleeved cables and sp 120 fans with black/red theme leds
i know its overkill too but for long term ? because ill use it for 5 years at least and watercool it when get some money .
i already bought the dell for 580$ i think its good price and its not bad monitor ( actually NICE  :D )
Thank you for your helpful post
https://linustechtips.com/topic/22852-first-awesome-build/#findComment-290972
Even for long term, you're spending too much money for performance you're probably not going to even touch.
https://linustechtips.com/topic/22852-first-awesome-build/#findComment-291104
What's this build going to be used for? It's AWFULLY expensive.
https://linustechtips.com/topic/22852-first-awesome-build/#findComment-295725
