So I got the parts for a pc put it all together and now I cant get windows to install to my ssd.
When it askes where I want to install windows I have 4 choices
Disk 0 partition 1 size:100mb free space: 78mb type:system
Disk 0 unallocated space size: 128mb free space: 128mb no type
Disk 0 partition 2 size: 238.3gb free space: 232.2gb type: primary
Disk 1 unallocated space size:1863.0gb free space: 2863gb no type.
I had just instaled windows but then I shut it off (not using the power button) and its now making me reinstall. Firat time I could pick my ssd. Now it says "windows cannot bw installed to this disk. The selected disk is of the GPT partion style". Can anyone tell me how to fix this.
I already set my ssd to my boot drive.
Yes I watched the video linus made on this but it says nothing about this :(
Thanks guys.
https://linustechtips.com/topic/227701-need-some-help/
did you unplug the USB drive or take out the DVD?
Planned I Hope Someday I Do First Build: CPU: Intel Core i7 5820k CPU Cooler: CM Hyper 212 EVO Mobo: MSI X99S SLI PLUS RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4-2133Mhz Storage: Corsair Force LS 240GB SSD & 2TB WD Green Graphics Card: ASUS GTX 970 4GB Turbo Case: NZXT S340 White PSU: EVGA SuperNOVA NEX 750W 80+ OS: Windows 8.1 64-bit OEM Monitor: AOC i2267Fw 60Hz 22" Monitor
https://linustechtips.com/topic/227701-need-some-help/#findComment-3117339
Disconnect all drives except for the SSD. Then delete all partitions and create an new one. You should end up with two. A small one 100Mb and the rest. install to the big one
As well do I delete the ssd file thats listed as primary?? And I cant delete the one with the name "disk 0 unallocated space"
Any ideas?
https://linustechtips.com/topic/227701-need-some-help/#findComment-3117408
Unallocated is just that. Nothing to delete. I think it say advance options then you can delete the created one. As in New. Disconnect any other  Drives or windows will place a boot partition on them and you could accidently delete your data
When you delete everything you should just have one as unallocated. Then create "New" it will make two partitions. Watch a you tube video
https://linustechtips.com/topic/227701-need-some-help/#findComment-3117457
Ok ill give that a go. I have no data on the drives as they are new from today.
https://linustechtips.com/topic/227701-need-some-help/#findComment-3117495
Ok deleted it then it game me back up one and the normal. Instaling to the other right now. Thanks I think I got it but not positive.
https://linustechtips.com/topic/227701-need-some-help/#findComment-3117507
