Hello, i need some help in choosing out components for a new PC build that i will do in 2 weeks. i am on a 700 US Dollar budget for this PC. i want to use it for gaming on a single 1080p monitor. i already attempted to pick out pieces myself and there will be a link below.  This is actually my first time building a pc and i want to make my parts are the best bang for the buck at this range. i don't need a hard drive or operating system. i don't need any thing else besides the pc at all. Thank You!
http://pcpartpicker.com/p/Gwkcyc
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/227301-new-pc-build-help/
it look good to me, though I will get this mobo instead http://pcpartpicker.com/part/gigabyte-motherboard-gah81d3 because I dont trust ASRock all that much and it's an ATX, it will be easier to work with compare to the tiny Micro ATX (not that tiny though, but I really dont like anything smaller than ATX xD)
My rig: Intel Core i7 4790k | MSI Z97 PC Mate | GSKILL Ripjaws X 16GB 1866MHz | ADATA Premier SP550 480GB SSD | Seagate Barracuda 3TB | Seagate Barracuda 2TB  | MSI Gaming X GTX 1070 | Thermaltake Versa N21 | Corsair CX550M Semi Modular PSU | AOC G2460PF 144Hz | Logitech G502 | GSKILL Ripjaws KM780  | GAMDIAS HEPHAESTUS V2  PCPartPicker | Old Build Log | New Build Log
https://linustechtips.com/topic/227301-new-pc-build-help/#findComment-3112644
ok so im going for the gigabyte motherboard, and does the bitfenix ghost have good airflow? and would the update bios thing be an issue?
Rigs I've Built
https://linustechtips.com/topic/227301-new-pc-build-help/#findComment-3112718
