i get this LED code constantly, PC never freezes or crashes at all. Ran it for 12 hours straight and it never failed. what does this code mean?
now got the 40 code when i rebooted. Maybe i got AA because i had made a change to bios settings? got 40 constantly as well when i use the PC
Current Rig:   CPU: AMD 1950X @4Ghz. Cooler: Enermax Liqtech TR4 360. Motherboard:Asus Zenith Extreme. RAM: 8GB Crucial DDR4 3666. GPU: Reference GTX 970  SSD: 250GB Samsung 970 EVO.  HDD: Seagate Barracuda 7200.14 2TB. Case: Phanteks Enthoo Pro. PSU: Corsair RM1000X. OS: Windows 10 Pro UEFI mode  (installed on SSD)
Peripherals:  Display: Acer XB272 1080p 240Hz G Sync Keyboard: Corsair K95 RGB Brown Mouse: Logitech G502 RGB Headhet: Roccat XTD 5.1 analogue
Daily Devices:Sony Xperia XZ1 Compact and 128GB iPad Pro
https://linustechtips.com/topic/227270-rampage-v-extreme-aa-code/
AA usually means successful boot. On my old GA-Z77X-UD5H "A4" would show after a successful POST. That LED only matters when the system fails to POST, the LED will freeze and tell you the issue(s).
So, nothing to worry about.
