My first plans for a INTEL based gaming system was a failure so i made up my mind and went the AMD side as i now do some gameplay recording using FRAPS and edit it......... I wanted the most horsepower on the lowest budget !!!!!!!!!
please tell me if this build will be good enough to suit my needs.
AMD FX-8350
MSI 990FXA-GD65
KINGSTON HYPERX BLU 2X4GB 1600MHZ RAM
COOLER MASTER HYPER 212 EVO CPU COOLER
SAPHIRE HD 7850 1GB
COOLER MASTER THUNDER 500W PSU (FROM MY PREVIOUS BUILD)
SEAGATE 500GB HDD 7200RPM  (FROM MY LAST BUILD)
WD CAVIAR GREEN 1TB-- FOR RECORDING GAMEPLAY
WILL PLAY AND RECORD AT 1080P AND ATLEAST AT 30FPS
PLEASE TELL ME IF THIS WILL BE FINE OR IF YOU HAVE ANY SUGGESTIONS TO IMPROVE MY BUILD THEN PLEASE TELL ME
CAN SPARE ONLY 40-50$ MORE !!!!
FX 6300 @ 4.2 Gigahurtz 1.325V ,  ASRock 970 Extreme 4 mobo  ,  Kingston Hyperx Blu 2X4GB @1600Mhz  , Asus GTX 960 DCU ii Black OC  , Hyper 212 Evo , Samsung 850 Evo 250 GB , WD 1 TB caviar Green , Xonar DG sound card , Seasonic M12ii Evo 620W PSU , Corsair 200R case ,4 random case fans.
https://linustechtips.com/topic/22725-please-help/
Man please dont use capslog, and this is not the right section for this question so a mod will have to move this.
and it will be fine.
I7 2600k @ 4,5GHz - 16GB Kingston 1600Mhz RAM - Asus Sabertooth P67 - Samsung 830 128GB SSD - 2x Caviar Black 1TB - ADATA 80GB Boot SSD - Club3D 7870 XT - 42" Panasonic 3D Led TV - 22" Samsung SyncMaster
https://linustechtips.com/topic/22725-please-help/#findComment-287385
Its an okay build nothing amazing, try and use a different program other than fraps to record also. It produces large files. I would really reccomend an i5 haswell chip.. Theyre alot better for gaming, but since youre editing aswell I would actually say thats a good choice of chip for that budget. Plus, you dont want to be adding anything else to that build really, unless you get a larger power supply.
CPU: i5 3570k                                 PSU: CX650 Corsair                 SSD: 128GB Samsung 840
RAM: 16GB Corsair Vengeance     Case: Zalman Z11                    HDD: 500Gb Toshiba & 1TB Western Digital
MOBO: ASrock Extreme 4 Z77        GPU: GTX 770
https://linustechtips.com/topic/22725-please-help/#findComment-287396
You should post this thread to "New builds and planning" section because there's more expert in there than here, but I guess someone would probably see this here...
In my personal opinion, I think your build is fine. If I would suggest anything, I'll say "Don't use FRAPS!". FRAPS uses a lot of cpu process, and you might lower your fps while playing which is not fun trust me. Use DXTORY instead or anything. And also, if you havent buy these yet, I say, invest on an nVidia graphics card because at sometime soon, nVidia will release a new dirver update which include SHADOWPLAY which will be helpful on what you're planning to do.
CPU: Intel Core i5 3570K ( raped to 4.4Ghz) | Motherboard: Gigabyte GA-Z77X-UD3H | RAM: Corsair Vengeance 8GB | GPU: ASUS GTX 980 Strix
Case: Fractal Design DefineR3Storage: 256GB Crucial MX100 & 1TB Samsung Whatevs | Display(s): ASUS MG279Q1x Cheap LG Shit
PSU: Corsair HX650 or something | Cooling: Corsair H80i | Keyboard: Ducky Shine 3 | Mouse: Roccat Kone Pure | Sound: SoundBlaster Recon3D PCI-e
https://linustechtips.com/topic/22725-please-help/#findComment-287542
