Optimal airflow help?
2x120mm front intake, 2x120mm top exhaust. That gives you neutral pressure inside case and is enough to keep dust out. If your GPU seems to be hot, add one 120mm to side.
As for built-in fan controller. It has molex for power and 2-3 fan connectors to hook your fans. You may need splitters if you want connect all fans to it.
anothertealtiger ·
Mumintroll ·
Posted in Programs, Apps and Websites3 -
ElDTac ·
HunterSVK ·
Posted in Troubleshooting2 -
Ozzi ·
Posted in Networking5 -
2
MadManMarsBar ·
Posted in Build Logs3 -
IAmAndre ·
4
play_circle_filled
Latest From ShortCircuit:
