PC may soon be under water question.
Solved by Jodomcfrodo,
This is what I'm thinking. I forgot to put Photon in the first post.
http://www.xs-pc.com/watercooling-kits/raystorm-d5-photon-ax360-watercooling-kit
I found this. Same reservoir and case.
EDIT: and this
http://www.tomshardware.com/answers/id-2018746/build-mount-xspc-photon-170-nzxt-h440.html
EDIT 2:
There is also this:
Looks like it could fit almost everywhere.
Featured Topics
heckboi ·
Posted in Cases and Mods0 -
1
heckboi ·
Posted in Graphics Cards0 -
7
3
2
Cheersmate ·
Posted in CPUs, Motherboards, and Memory9 -
2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
