Hi guys, sorry if wrong topic.
Could you recommand me a store/website with good cable extensions?
I am looking for good quality cable extension.
What I need is 24 pin, 3x6 pin,
something like:
http://www.microcenter.com/product/340940/CableRight_Single_Braid_24-Pin_Male_to_Female_Power_Supply_Extension_Cable_-_Black_-_12
What's more, I need those at the bottom of mobo
Could you help? :)
https://linustechtips.com/topic/226774-cable-extension/
Bitfenix makes cable extensions for ATX CPU AND PCIE
those lower cables , i guess search on Ebay , but that motherboard pin out is very manufacturer specific
Main Rig : i7 5960X - 16GB DDR4 LPX 2400mhz - Asus Rampage V - 980GTX Ti - AX1200i - 650D - H110 - 1TB 840 EVO SSD - 30 inch HP 1600p IPS + 2xHP 20 inch 1600x1200 PLP setup! - Oculus DK2 - Logitech G502 - Corsair K70 RGB - Fanatec GT3 Wheel
i7 3930K - 16GB DDR3 2133mhz - Asus Rampage IV - 2 x 680GTX - AX850 - 550D - H100i - 256GB 830 Pro SSD - 2713HM 1440p IPS - G5 -
i5 3570K - MSI SLI Z87 motherboard - 4GB Corsair 1600mhz - Adaptec 31205 - Dell Perc 5/i - Intel Quad PT1000 Gigabit Network Card - Loads of 4TB RED's - +-70tb total storrage - HX850watts - Ri-Vier 24bay 4 U case
https://linustechtips.com/topic/226774-cable-extension/#findComment-3106020
anyone?
As said bitfenix ones are the most complete for the smaller and finer connectors but Icemodz does have a selection of PET sleeved extensions for the front panel and other ports.
http://www.icemodz.com/webshop/#!/Front-Panel-Extension-cable-Kit/p/24528009/category=5739188
Here's another option also from FrozenCPU:
http://www.frozencpu.com/products/17760/cab-1057/Phobya_Front_Panel_Extension_Cable_Kit_-_300mm_87487.html#blank
https://linustechtips.com/topic/226774-cable-extension/#findComment-3139686
