So I'm building my first pc. I'm building in an NZXT H440. mobo is ASROCK Extreme 6. Corsair H100i. HX750i power supply.
First problem I've run into is I swapped out the stock fans for sp fans, well, the new sp fans have very short cables. Is there an extension cable I can buy for those front 3 fans that can't make it to the mobo? Also the sp fans have a 4 pin connector so the extension would have to be a 3/4 pin for mobo to 4 pin to connect the fan. This mobo only has 4 fan connectors. 3 chassis fans, and a power fan.
https://linustechtips.com/topic/226593-much-needed-help/
https://linustechtips.com/topic/226593-much-needed-help/#findComment-3104486
