So, I've had my 780Ti for about 5 months now, and just recently I saw that it have started to get really warm when gaming, It's on 82 celsius when playing any game, and It have never been like that before.. All my fans are spinning, and I can't really see much dust on the graphics card itself.. Any ideas?
https://linustechtips.com/topic/226239-overheating-issues/
How do you have a 780ti on 82 degrees in the first place? Unless you have a stupid extreme OC or something it should never even come close to that. How many intake/outtake fans do you have in which case?
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/226239-overheating-issues/#findComment-3099008
I have 7 fans in an Phantom 530.. 1 200mm front, 2 200mm top, 1 140mm bottom, 2 140mm in the back, 1 120mm on the side. And the one on the graphics card. I have not OCd, and it started getting this hot yesterday..
https://linustechtips.com/topic/226239-overheating-issues/#findComment-3099031
I don't even know how it can run this hot. Open up the case and undust EVERYTHING properly and check whether the GPU fan connectors got loose. If the GPU still gets that hot after that then it sounds like something bad happened that might require an RMA.
https://linustechtips.com/topic/226239-overheating-issues/#findComment-3099042
Yeah, I'm going to dust it when my father gets home. Hopefully it will be alright..
https://linustechtips.com/topic/226239-overheating-issues/#findComment-3099062
