So, out of curiosity I decided to get the average frame rates from a few games, and then turn on "Optimal" mode to see if it would make a difference, and instead of 3.4Ghz (3.811Ghz max 1 core) on a 3570k it went up to 4.2Ghz, didn't notice a difference so I changed it back to "Normal"....only problem is the OC is still there and will not go away....suggestions?
https://linustechtips.com/topic/22585-asus-mobo-optimal-mode-problem/
Have you tried putting the settings back to default?
As in clicking on "Normal" ? or going back to bios default settings?
Bios default.
Bios default.
No, although I may have settings in there I would like to keep so I'm reluctant to do that...here's the story: Everything in it is new but the hard drive, I took it out of my old computer and it was..."restored to dissimilar hardware" without formatting it or anything...so I'm not 100% sure that it would be a good idea to do that, could be talking outta my A** though not sure.
Just go into your multiplier and set it to 38..Or set system default in bios..It should not change anything important..Plus when i go into my Sabertooth bios every time it ask if i want to load previous values..So even if you mess it up you can go back in and reload previous values..If yours is like mine at least..
Okay, will go do that now, be back in a few.
I hope you can fix your problem without much hassle but it's generally recommended to reinstall windows to make sure the drivers are all working fine.
Update: Fixed it, the reset to default got rid of the "optimal" (yeah right) mode and I'm back to stock frequency, although I had to deal with the messed up hard drive as I explained above..if I hadn't been such a ding dong and recorded the BIOS changes that were made to get it to run I could have avoided all of this....oh well, first time for everything right?
