So the past few months, My computer has been starting up and going into the repair screen. It goes through the usual process to attempt to repair and restore to a previous date. But it did that maybe once in a blue moon. Now it seems like it's happening every other day. Does anyone know if it's a case of my hard drive dying due to age(3ish years), or maybe something else?
I do keep most of my data backed up on an external. But I don't keep the OS backed up. I plan to RAID it in the next few weeks. But I can do that sooner than later if it's suggested.
PC:
Intel i7 2600
NVidia GTX 550 Ti
8GB RAM
Seagate Barracuda ST1000DM003 1TB 7200RPM (OS Hard Drive. Not Raided)
Seagate Barracuda ST1000DM003 1TB 7200RPM (Second Drive. Not Raided)
https://linustechtips.com/topic/225648-hard-drive-dying/
https://linustechtips.com/topic/225648-hard-drive-dying/#findComment-3091071
I'd had a old WD Black from 4.8 years ago, and it started to makes noises and loud noises but never foced to the repair screen but WD replaced it :D. If you do have to replace the drive I'd suggest WD as they have never Died on me.
In your case you could back up the data to the second hard drive then do a complete re-install of the computer's OS and that should fix any issues if it is Software base.
Project Casper - Glass Tubing Build
Ryzen 9 5905x     |    Gigabyte Aorus Extreme X570    |   Strix 3090
GSkill 64gb 4000mhz   |    EVGA 1600T psu     |      3x Samsung 980 Pro NVME 1tb Raid 0
  4 x Crucial MX500 2tb raid 0   |    Glass Hard Line Tubing  - EKWB Blocks
https://linustechtips.com/topic/225648-hard-drive-dying/#findComment-3091098
The hard drives do not make any noises that aren't out of the usual. No strange sounds or anything that I can hear.
How old are the drives?
Do they make any weird noises?
The OS drive is maybe 3 years old.
The second was purchased this year.
https://linustechtips.com/topic/225648-hard-drive-dying/#findComment-3091142
Try a fresh install... 3 years is nothing for HDDs...
I'd suggest ^this^... But check the SMART data with CrystalDiskInfo first...
https://linustechtips.com/topic/225648-hard-drive-dying/#findComment-3091172
I have had bad experience with those drives i had one give out actually about a month ago it had tonnes of bad sectors and then just failed
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/225648-hard-drive-dying/#findComment-3091182
