Hi, my old computer died the other day so im going to turn it into a home server / nas unit.
I will be creating a simple raid 10 NAS using motherboard onboard controller, the components used in this build are as follows:
- AMD A8 5600k APU
- Gigabyte GA- F2A85X-UP4 Motherboard
- 4 WD 2TB Red Drives
- Seasonic S12II 430W Powersupply
- G.SKILL Ripjaws - 1066CL7D - 4GBRH (2x2GB) DDR3 Ram
Or would swooping out the apu and motherboard for
- AMD FX 4130 CPU
- Gigabyte GA - 990FXA - D3 Motherboard
Be better?
Please help as I'm new to NAS/ Homeservers, Thanks :)
https://linustechtips.com/topic/22548-help-with-a-nas-build/
If all you're after is a NAS/fileserver, an APU is totally overkill. You could just get an atom board with something like a D2550 on it, whack a single 4GB DIMM onto it and you'll be fine (atoms only run single channel anyway). Jetway do a few atom boards with 4 SATA ports on them which would be fine for a software RAID or Hardware RAID if you bought an LSI card or something. Alternatively you could get a H67 socket 1155 board and get a £30 pentium or something on that, allowing you to have up to 6 drives on Intel's firmware RAID. For 24/7 use, power consumption should always be a consideration in my eyes, and the Atom is the king of power consumption.
For this reason AMD is really not a great choice for NAS/fileserver applications. They have far higher power consumption and inferior NICs, plus the Intel RAID is better anyway.
https://linustechtips.com/topic/22548-help-with-a-nas-build/#findComment-284758
Will sata 2 be slower versus sata 3 in a raid 10 ?
The bandwidth of sata 3 is definitely bigger, but I don't think 4 mechanical drives would reach the limit of 375 MB/s (sata 2) in raid 10 any ways.
Main rig: i7 3770K @ 4.54, Sapphire R9 290, Sabertooth Z77, 16 GB Mushkin Redline 2133, Lian Li PC-P50R, Seasonic 860xp Platinum, Kingston Hyper X 3K 240GB
freeNAS server: AMD Athlon II 170u 20W, 5 x 3TB WD Red in raid-z1 (12 TB)
media centre: AMD A10-5700, crucial M4 (boot), running XBMC,4 x 3TB WD Red, 3 x 3TB WD green + 2TB green in FlexRAID (17 TB)
https://linustechtips.com/topic/22548-help-with-a-nas-build/#findComment-285846
And he will likely be using a 1Gig NIC, so he doesn´t need the speed their either :p
Respect the Code of Conduct!
>> Feel free to join the unofficial LTT teamspeak 3 server TS3.schnitzel.team <<
>>LTT 10TB+ Topic<< | >>FlexRAID Tutorial<<>>LTT Speed wave<< | >>LTT Communies and Servers<<
https://linustechtips.com/topic/22548-help-with-a-nas-build/#findComment-286317
And he will likely be using a 1Gig NIC, so he doesn´t need the speed their either :P
I agree. As for what board to get, just find one with a chipset which supports Intel Matrix RAID - H67 is usually the cheapest though (Q75, Q77, H77, Z75 and Z77 also do, as do a few older Sandybridge ones (Q67, P67, Z68))
Regarding a RAID card, with RAID 10 you won't notice much difference since there's no parity calculations. If you were after RAID 6 I might advise one, but even for RAID 5 I've found matrix RAID is fine if you don't need the CPU to be doing something apart from organising the storage.
https://linustechtips.com/topic/22548-help-with-a-nas-build/#findComment-296021
