My school recently got a 3d printer and I decided to make this little project for myself. I haven't printed this yet but I will in a couple of days. I measured this to my own case (HAF 912) and still may not have gotten the right measurements and i designed it to be behind the covers. This is my first attempt at any 3d modeling so I just wanted to share it if anyone wanted to use it.
Sketchup file
STL file
CPU: Intel i5 2310 Mobo: MSI Z77A-G41 GPU: MSI 760 Twin Frozr 4GB RAM: 8GB ADATA XPG Gaming Series
Storage: OCZ Aglility 3 120 GB SSD, 2 250GB Segate HDDs Case: Cooler Master HAF 912 PSU: Antec NEO ECO 520W
https://linustechtips.com/topic/225448-drive-bay-fan-mount/
as long as you print it upside down from how it is shown in that picture you should be fine (if you are using an pla or abs printer and not one that uses powder.) otherwise when the top gets printed it will sag in because there is no support.
System CPU : Ryzen 9 5950 doing whatever PBO lets it. Motherboard : Asus B550 Wifi II RAM 80GB 3600 CL 18 2x 32GB 2x 8GB GPUs Vega 56 & Tesla M40 Corsair 4000D Storage: many and varied small (512GB-1TB) SSD + 5TB WD Green PSU 1000W EVGA GOLD
You can trust me, I'm from the Internet.
https://linustechtips.com/topic/225448-drive-bay-fan-mount/#findComment-3088411
What size fan?  2 or 3 5.25 bays?
@Trouble Kelp
120mm fan and 5.25 Bay but again it's for my case so idk if it will fit for everybody
https://linustechtips.com/topic/225448-drive-bay-fan-mount/#findComment-3088481
It looks like it will need three 5.25" bays, is this correct?
If so then it should fit any case with three 5.25" bays, assuming there are no clearance issues inside the 5.25" bays.
This is an awesome project for a 3D printer and a great use of extra 5.25" bays, thanks for sharing :D
Edit: Most 5.25" bays have metal shelf parts that support the drive, does your design clear these or are these absent in your case?
"PSU brands are meaningless, look up the OEM."
https://linustechtips.com/topic/225448-drive-bay-fan-mount/#findComment-3090767
Thanks.
I measured for that so it should  avoid any conflict with those tabs but again my case may be different and I haven't actually tried it yet so I can't confirm that it works
https://linustechtips.com/topic/225448-drive-bay-fan-mount/#findComment-3095297
