"The average selling price for a PC case is $80, so start saving up if you want one of these bad boys that is due out later in Q1 2013. Legit Reviews will bring you more coverage of the Corsair Obsidian 900D at CES 2013 next week!" Late Q1 http://www.legitreviews.com/news/14818/
[9:01:47 PM] Slick: And the award for life time acheivement in the field of "maker of the least amount of sense" goes to Kilmer.
https://linustechtips.com/topic/2254-case-question/#findComment-30263
I just take off the side panel so that I can view the inside of my case at all times. Windowed cases are sooo overrated!
https://linustechtips.com/topic/2254-case-question/#findComment-30280
part 1=bad part 2=no
Why is that? I keep it on top of a small table next to my cpu desk and it keeps it cooler. It also allows me to see everything instead of in a tiny window.
https://linustechtips.com/topic/2254-case-question/#findComment-30289
30 seconds of cleaning a day will keep it dust free.
https://linustechtips.com/topic/2254-case-question/#findComment-30970
Don't come onto the forums asking people for stuff then insulting them for suggestions. That crap is uncalled for.
What if you looked at modding your side panel and putting a window in? You oughta look it up on Google and see if it can be done. I don't see why you shouldn't be able to. Spending a few hundred on a new case for a window seems like a bit of a waste, and more fans isn't going to make alot of difference in temperature. It probably won't be worth it for how much more noise it will make.
https://linustechtips.com/topic/2254-case-question/#findComment-31158
I have worked that out by rearranging the layout of my fans I have air coming in the back via 3 fans and then exhausting out the front.
https://linustechtips.com/topic/2254-case-question/#findComment-31180
