Hi guys, so I'm planning a build for a friend. He's looking to be in the $750-$800 range and so far I have this:
http://pcpartpicker.com/p/fFB8P6
He'd like to keep the case and the inclusion of an ssd, so I'm thinking I might scale back the gpu a bit to allow for an after market cooler to overvolt the pentium.
Speaking of which, I'm looking for either a heat-pipe style fan design, or a single radiator design. Thoughts?
Also looking to get a portable monitor as this is a rig which might be moving around a bit, so recommendations for that would be appreciated as well.
Thanks,
https://linustechtips.com/topic/225391-build-recommendation/
new mobo and ram otherwise looks good http://pcpartpicker.com/p/6r2pD3
Please follow your topics guys, it's very important! CoC F.A.Q  Please use the corresponding PC part picker link for your country USA, UK, Canada, AustraliaSpain, Italy, New Zealand and Germany
also if you find anyone with this handle in games its most likely me so say hi
https://linustechtips.com/topic/225391-build-recommendation/#findComment-3087518
here is a polished version http://pcpartpicker.com/p/KCszpg
https://linustechtips.com/topic/225391-build-recommendation/#findComment-3087562
Is there really going to be a major performance benefit with higher speed ram?
What makes this motherboard better. It looks basically the same, and is higher priced, and isn't in the color scheme (less of a problem).
Other than that looks good. Thanks for the cooler recommendation.
I would make sure that 280x will fit in that case
Good point. I'll look into it and make sure.
https://linustechtips.com/topic/225391-build-recommendation/#findComment-3087636
