So tomorrow I will order some fans for my case, since the old fans are not really good for airflow. But before that, I want to ask something that really bother me about fan cases:
If I have say like 4 fans on the case, and there is only 3 fan connector, what should I do with the other one? should I use the molex adapter? I've already try it and the fan runs really noisy.
thank in advance.
https://linustechtips.com/topic/22538-question-for-case-fan/
thank in advance.
You could use a Y spliter cable to connect more than 1 fan to a single Fan header on the motherboard.
https://linustechtips.com/topic/22538-question-for-case-fan/#findComment-284512
get a fan splitter, i know phobya has some, i think noctua has some too like these: http://www.newegg.com/Product/Product.aspx?Item=N82E16812162026
search for fan splitter or fan y cable, there are some that use a 4 pin and a molex but you can plug in up to 8 fans to a single connector
https://linustechtips.com/topic/22538-question-for-case-fan/#findComment-284519
2 to 1 fan splitter gets the 4 fans into 3 ports and very cheap too.
PC Builder, Engineer... BACON    Project Cobalt: http://linustechtips.com/main/topic/38058-project-cobalt-copper-piping-laser-etching-and-more/#entry489258
| NZXT Switch 810 | i5-3570k | gigabyte UD-5H | Corsair Vengeance 8gb ram | GTX 670 | 2x 60gb intel 330 series ssd's in raid 0 | 1tb seagate barracuda hdd | Corsair tx750m | XSPC razor GPU and CPU waterblocks | XSPC d5 vario pump | Thermochill Pa140.3 | phoyba 280mm radiator | Chromed Copper tubing |
https://linustechtips.com/topic/22538-question-for-case-fan/#findComment-284529
Which fans did you get? Some higher end fans come with splitter/extensions/low voltage adapters already.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/22538-question-for-case-fan/#findComment-284943
