Depends on your other components.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
https://linustechtips.com/topic/225117-help/#findComment-3083838
Depends on your other components and budget. If you're not doing an all out build, go for an AIO.
well i am from australia and i want to get them from pccasegear and my budget is $4000 and this is what i came up with https://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=357840&action=wish_lists
https://linustechtips.com/topic/225117-help/#findComment-3083847
If it's your first PC then go with a AIO.
I don't think this is the right way to think about it. My first PC is the one I have now, with a custom loop.
https://linustechtips.com/topic/225117-help/#findComment-3083848
Personally, I would get a couple of 980's and ditch the water cooling until next year.
https://linustechtips.com/topic/225117-help/#findComment-3083851
I'm fairly confident in saying you're in a minority. Don't get me wrong, it's awesome that your first build is watercooled, but most first-time builders aren't really up to the task. With custom watercooling you aren't getting much of a return on your investment compared to AIO's. Custom watercooling is generally something enthusiasts do just because it's awesome.
- Now with added  WUB WUB -
https://linustechtips.com/topic/225117-help/#findComment-3083912
You make a very good point... I'm actually in agreement with you now.
https://linustechtips.com/topic/225117-help/#findComment-3083918
