Best case fan?
Go to solution Solved by Nico123473,
noctua industrial ppc look better and perform the same or better than the nf 12
Anything that is rusty red and has the word noctua in front of it...
AMD 8320 with Noctua NH-D15|ASrock Fatallity Killer 990fx|Sapphire Tri-X R9 290|8gb HyperX Fury Black 1866 MHz|Thermaltake 850W Gold|NZXT H440|Logitech G19s||R.A.T 9|Razer Vespula|Astro A50|Corsair Voyager GT 64 gb
Comp overclocker - Tinkerer - I thoroughly enjoy putting 12v into things that say 5v
https://linustechtips.com/topic/225087-best-case-fan/#findComment-3083537
For a case fan, the noiseblocker black silent pros are good. As are the noctua NF-F12s and, slightly less so, the bitfenix spectre pros, but don't get the pwm spectres, as there are a number of cases of the classic pwm ticking noise.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/225087-best-case-fan/#findComment-3083567
Planned I Hope Someday I Do First Build: CPU: Intel Core i7 5820k CPU Cooler: CM Hyper 212 EVO Mobo: MSI X99S SLI PLUS RAM: Corsair Vengeance LPX 16GB (4x4GB) DDR4-2133Mhz Storage: Corsair Force LS 240GB SSD & 2TB WD Green Graphics Card: ASUS GTX 970 4GB Turbo Case: NZXT S340 White PSU: EVGA SuperNOVA NEX 750W 80+ OS: Windows 8.1 64-bit OEM Monitor: AOC i2267Fw 60Hz 22" Monitor
https://linustechtips.com/topic/225087-best-case-fan/#findComment-3083639
This
CPU: i7 3770k@ 4.6Ghz@ 1.23v - GPU: Palit GTX 660ti - MOBO: Asrock Extreme 4 - RAM: Corsair vengeance 8GB 1600Mhz - PSU: OCZ 650watt - STORAGE: 128Gb corsair force GT SSD/ 1TB seagate barracuda 7200rpm
        COOLING: NH-U14s/ 3x Noiseblocker blacksilent pros/ Silverstone Air Penetrator/ 2 corsair AF120s
https://linustechtips.com/topic/225087-best-case-fan/#findComment-3084290
