I used google chrome about 6 months ago. I used it with no problem but decided to switch to firefox for a while. I uninstalled chrome back then.
Now, I decided to switch back again to chrome but now when I install it, whenever I start it - chrome just crashes. The browser window doesn't even open, it just crashes. Needless to say I am running Win 8.1 64bit
I have seen people giving advice that you should remove corrupt profiles from C:\Users\[uSER_NAME]\AppData\Local\Google\Chrome\User Data\Default , but the User Data folder is empty
Any advice?
post-35250-0-21082100-1411989596_thumb.j
~Issue is resolved~
https://linustechtips.com/topic/224463-help-with-chrome-crashing-problem/
What does it say when you click "view problem details"?
Use something like IObit uninstaller to uninstall chrome and do a powerfull scan to remove left overs. And then download the 64bit chrome version.
--- CPU:  AMD A10-7850k --- Motherboard:  ASUS X88MPlus --- RAM:  G-Skill 8GB Ripjaws X DDR3 2133 Dual --- GPU:  Integrated APU --- Case:  Aerocool Dead Silence Gaming Cube Case  ---
I had a somewhat similar problem, I just waited a bit and re-downloaded it (probably after it had a few updates).
Try completely uninstalling it and then re-installing it. If that doesn't work you'll need to use a different browser and try chrome after it's been updated.
if you really want to use chrome try the 64 bit version called canary cchrome
CPU: Intel Core i5 4690K @ 4.6Ghz CPU Cooler: Noctua NH-D15 GPU: GTX 1070 TI RAM: Crucial Ballistix Tactical 16GB (4x4) Mobo: ASUS Z97-PRO(Wi-Fi ac) PSU: Corsair RM Series RM750 Case: Fractal Design Define R4 no window
I uninstalled and cleaned leftovers with Revo uninstaller pro. Restarted my PC, installed the canary chrome - still crashes. I get this
Problem signature:
  Problem Event Name:    APPCRASH
  Application Name:    chrome.exe
  Application Version:    40.0.2172.0
  Application Timestamp:    54281e0e
  Fault Module Name:    FASTAN~2.DLL
  Fault Module Version:    0.0.0.0
  Fault Module Timestamp:    537cb8dd
  Exception Code:    c0000005
  Exception Offset:    00000000000c4923
  OS Version:    6.3.9600.2.0.0.256.48
  Locale ID:    1053
  Additional Information 1:    ad20
  Additional Information 2:    ad2052222f4ee2ec436c9df4980b6a92
  Additional Information 3:    3901
  Additional Information 4:    390142b65afcf1447b8cf9f557e56b9b
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=280262
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
Issue is resolved. I had something called Fast and Safe on my PC. I deleted it from C:\ProgramData\Fast And Safe and now it works.
if a program has to be called "fast and safe" it's probably the exact opposite :/
