What is The Pros and Cons of AIO Water Cooling ?
Just wanna know . What is The Pros and Cons of AIO Water Cooling ?
Pros;
Most radiators 120/240/360 AIO liquid coolers are capable of being mounted into most *thought-out) medium MATX up to large (E-)ATX supported cases.
Software wise inclusion of support for changing fan curves/pump rpm on the fly (NZXT & Corsair are pioneering this section quite neatly)
Better cooling then most air-coolers (if not par) under the price point.
Neutral;
Based on the price of the cooler can be a large difference.
Some decent air-coolers $50+ have as better fans then pre-done liquid coolers.
Cons;
Plain expensive sometimes.
Coolant has no antimicrobial fluid (overtime build up of dirt etc.)
Tubing/Fittings aren't made of a decent quality material, rotatable for ease of use whilst installing & no flexibility routing.
