64-bit key same as 32-bit key?
Go to solution Solved by xAcid9,
Yes
Yes
Hey guys, so I have an old windows 7 pro key from a laptop (64-bit) and I am installing windows 7 pro (32-bit) on an old computer, will the key work on the 32-bit?
Hmmm....I'd not be as quick to say there would be no problem. Usually, the Windows key is tied to that laptop only since it's an OEM product key. Try activating that key on a totally different PC, you're moving from laptop to desktop, and you may not be able to....you may have to call the helpline for activation and I don't think they'd entertain it.
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
It worked just fine :) Thank you for your help tho!
Ran by coffee
Once again this is a big misconception. Laptop manufacturers do NOT register windows with the key on the bottom of your laptop. They use a manufacturers key. They do this because typing every single unique windows key would be ridiculous  on a manufacturing scale. When you buy a laptop you are also entitled to one reinstall worth of windows ie. one key. So they attach the key that has NEVER BEEN USED to the bottom of your laptop in case you ever have to reinstall windows. Meaning if you have an old laptop which has a key on the bottom YOU CAN use the key on another machine with no problem. Is it OEM? Yes, but it also isn't registered. This is just one more post proving it will work.
I'm bookmarking this for future reference on this forum to everyone who says that you can't use the key on the bottom of a laptop. You've proven what I already knew and while people will still spread misconception. At the very least it might educate a couple people.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
I've used codes for the bottom of laptops and desktops across each other forever, I've just ever used arcoss 32-bit and 64-bit
Ran by coffee
I have too, but there is so many young kids here who believe it wont work. No matter how many times they are told or what proof they are shown they refuse to believe they are wrong.
Unless it specifically says so you'll be fine, I've had a few that were specifically labeled 32-bit or 64-bit, mainly older Win 7 machines.
"I take my spirit and I smash my mirrors,
And now the whole world is here for me to see,
Now I'm searching for my love to be."
-Jimi Hendrix, Room Full of Mirrors
I work for a small oem that sells industrial pc's and like you said If I had to type every pk by hand that would take me forever.
How we work is we have an image for each model pc so we just image hard drives for each model we sell.
And that's how the big oem's work they just have imaged hard drives with same pk for each model.
If you don't believe me find two hp's or dell's and run produkey and they will be the same key.
So scaryjam know's what he is talking about and anyone who says otherwise is wrong.
Here is a condensed version of how it works.
http://www.guytechie.com/articles/2010/2/25/how-slp-and-slic-works.html
