The mounting is the same as standard LGA 2011.
https://linustechtips.com/topic/222376-lga-2011-3-cpu-blocks/#findComment-3047677
Planning a 2-way sli x-99 build for a friend, and i'm not having luck finding a cpu block for the new socket, or am i just not looking hard enough?
I'm pretty sure XSPC's Raystorm and Swiftech' Apogee XL both work on 2011-v3. As do  all LGA2011 blocks and most lga1150 blocks (as most modern blocks are interchangeable across all platforms).
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/222376-lga-2011-3-cpu-blocks/#findComment-3047683
So something like an EK Supremacy shouldn't be an issue?
https://linustechtips.com/topic/222376-lga-2011-3-cpu-blocks/#findComment-3047697
Nope, it'll work fine.
PSU Tier List | CoC
https://linustechtips.com/topic/222376-lga-2011-3-cpu-blocks/#findComment-3047706
http://www.frozencpu.com/cat/l3/g30/c325/s1572/list/p1/Liquid_Cooling-Water_Blocks_CPU_-_Socket-CPU_Socket_LGA2011-Page1.html
LGA2011 block support includes 2011-3 CPUs, just make sure the block you're purchasing has all of the parts necessary (check specs/features or look at compatibility guide on this site, for example).
https://linustechtips.com/topic/222376-lga-2011-3-cpu-blocks/#findComment-3047760
