Hello,
I'm planing to get rid of my Corsair TX850M V2 and want to buy a new one, but this time i want a PSU that has 6+2 PCI-E Cables but the +2 cables come from the PSU and not "robbing" power from the 6 cables like i have in this Corsair PSU
I have 100€ and the store needs to be in Europe and at least Semi-Modular
I was thinking on XFX 650W XTR, it cost 92€ on my country
But i'm afraid with only 650W because i change graphics every year and for some reason the next generations can consume a lot of power.
Specs:
i7 3770k - 4.2Ghz
GTX 970 4GB
SSD
2xHDD
P8Z77-I Deluxe
8GB 2600Mhz
Bitfenix Prodigy
Thanks
https://linustechtips.com/topic/222102-need-psu-for-itx-case/
The Silverstone Strider series fit in these cases well and there is a short cable kit available for around 20 bucks which is very much worth it for ITX systems.
For your system the 650W version would be more than plenty :)
It would probably draw 400Watts maximum.
https://linustechtips.com/topic/222102-need-psu-for-itx-case/#findComment-3044500
It's hard in Portugal to get SilverStone products
I have this 2 PSU:
XFX 650W XTR (P1-650B-BEFX)
XFX Pro 750W Black Edition (P1-750B-BEFX)
Without counting the 100W difference what is better? Both are 100% modular
More 30€ i can get to this one:
Corsair AX760 (CP-9020045-EU)
Is worth the extra money? Already sits at 150€, its a bit far from what i want to spend.
https://linustechtips.com/topic/222102-need-psu-for-itx-case/#findComment-3077618
