Hard Drive Not Found?
Go to solution Solved by DKM1129,
Right click on my computer and click on manage this will take you to the computer management program on Windows then click on storage and disk management if your 1tb HDD is shown there then you should make it online if it already isnt and then create a file path for it, it should show up in my computer after that
On my recent, and first, build, I set up Windows 8.1 on my Samsung 840 Evo 240GB. Now that I have started to download programs with a lesser priority, I find my self trying to download them onto my 1TB hard drive, however, it cannot be found. It appeared as an option to download the OS onto when I first set it up. Any suggestions?
CPU: i7 4790k @ 4.6 GHz Motherboard: MSI SLI Plus Krait Edition RAM: 16 GB (2x8) 1866 MHz Kingston Black Fury Series GPU: Gigabyte GTX 970 G1 Gaming Case: NZXT S340 (Black) Storage: Intel 730 Series SSD (240 GB), Seagate Barracuda (1 TB) Display: LG 24MP55 Cooling: Cooler Master Hyper 212 Plus Keyboard: Corsair K95 RGB for gaming (1st Player Fire Dancing for typing) Mouse: Logitech G502 Sound: Corsair Gaming 2100 Vengence 7.1 Headset Operating System: Windows 10
https://linustechtips.com/topic/221891-hard-drive-not-found/
Make sure its plugged into the native intel SATA 3 ports on your motherboard, not the 3rd party controller ones.
https://linustechtips.com/topic/221891-hard-drive-not-found/#findComment-3041378
Does it show up under computer?
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/221891-hard-drive-not-found/#findComment-3041438
https://linustechtips.com/topic/221891-hard-drive-not-found/#findComment-3041527
Thanks!
https://linustechtips.com/topic/221891-hard-drive-not-found/#findComment-3041594
