just a quick background as ive just joined recently I have been sick of the lag I get on my laptop while gaming on things like csgo, dayz (11 fps if im lucky heh) and many more but too many to name, so my girlfreind was asking about doing a custom build for her and i thought well crap why don't I do one too?
so ive asked around to friends and gamers i play with on servers and such and a recent mate told me to come on here and talk to you guys, with my build i have it setup as not a minimal but not a all out build as i want something that will operate decently while i can still build it up in the future, thus i want to do water cooling so im not constantly changing the airflow and replacing fans and wiring them (had enough of that with a amplifier in a sound system dont ask)
I want to do a kind of portal theme on the inside and i have researched and seen i may need to change the tubing every couple of years or so as well as orings for the fittings, but thats why i got the orange and clear tubing so it will be orange on some parts and blue on others or orange on the parts were it will be hot to the radiator then blue were it would be cold to be figured out later when i start the build, also i am going to do a filling and dumping valves for the reservoir which will explain the extra fittings
the link below is the loop and build i plan on making and buying over a 2 month period i want to know from you guys should i use barbed connection with clamp or just compression fittings pros and cons of this build any advice you can give will be greatly appreciated thanks!
http://www.pccasegear.com/index.php?main_page=wish_lists&wlcId=354493&action=wish_lists
https://linustechtips.com/topic/221330-first-build-water-cooled/
Don't water cool a 270X.... Take the money you'd spend on water cooling and use it on better hardware.
sorry it might not of been explained in what i said but the point of doing water cooling now is so i can just get that done out of the way despise being pointless or op for the system when i upgrade in the future the loop is already there and able to be modified this is just my first build i have ever done and plan to add alot in the future and upgrade to better and more recent hardware
https://linustechtips.com/topic/221330-first-build-water-cooled/#findComment-3034007
Yeah but you'd have to spend money for two things when you upgrade. It's not worth it. Get a great system now and work on the water cooling later. You'll end up saving money.
https://linustechtips.com/topic/221330-first-build-water-cooled/#findComment-3034012
yeahhhhh im not one to be bothered by money but shhh dont fight it i have my eyes set on a water build as many people may find stupid its what i want to do
https://linustechtips.com/topic/221330-first-build-water-cooled/#findComment-3034031
Are you sure you want to give up a LOOOOOOOOOOOOOT of performance just for a nice looking computer?
https://linustechtips.com/topic/221330-first-build-water-cooled/#findComment-3034039
well for now yes untill i upgrade it in the future like i said this build is only temporary im not going to keep it like this plus when i do upgrade will probably just try to sell off the old parts or use them to slowly build up another build and sell that
look im just asking about the loop not if i should have it or not
https://linustechtips.com/topic/221330-first-build-water-cooled/#findComment-3034069
Your method seems flawed. If anything LCing a system is more costly/more effort as any changes you make to the system require a full drain of the loop + new waterblock (for a new GPU). Vs just changing a fan or two.
well by the time i do upgrade it would be a good excuse too put in new coolant and check orings and such, i love the tinkering maintence and extra effort, ive worked on speedway cars for 4 years plus my own car from 1977 this kind of expensivish tinkering is what i love doing :)
https://linustechtips.com/topic/221330-first-build-water-cooled/#findComment-3034338
Ehh if you are going to have a water cooled system, don't get a 270x.
 CPU Intel Core i7-4790K  | Motherboard Asus Sabertooth z97 Mark 1 | RAM Corsair Dominator Platinum 16gb 1866mhz | GPU EVGA GeForce GTX 980 w/ ACX 2.0 | Case Fractal Design Define R4 w/Window | Storage Western Digital BLACK SERIES 3TB 3.5" 7200RPM + Samsung 840 EVO 250GB |  PSU Corsiar RM750 | Display(s) Some Acer Things | Cooling Corsair H100i + 5x Noctua NF-F12 industrial 120mm fans(they are freaking load) | Keyboard Corsair Vengeance K95 |  Mouse Logitech G502 | Sound Audio-Technica AD900x + 02+ODAC +AT2020 | OS Microsoft Windows 8.1 Pro
https://linustechtips.com/topic/221330-first-build-water-cooled/#findComment-3034378
oh? what would you recommend as its a first build i want cheap but not the cheapest but worth the money
Get a 270x by all means but dont LC it for now. Keep your loop to CPU only (for now). Save up for a beast of a GPU (AMD's new 390x/980gtx + block) and then extend your loop.
You get to do your expensive tinkering then :D
Quack 🦆
https://linustechtips.com/topic/221330-first-build-water-cooled/#findComment-3034584
awesome mate exactly the feedback i was hoping for :)
as for links does anyone have preferences for compression or barbed?
also would it be flawed to do up 2 separate lines to the loop, one into and one out of the reservoir so i can empty or fill the system with out taking the whole thing out?
https://linustechtips.com/topic/221330-first-build-water-cooled/#findComment-3035011
EK clean csq compressions all the way. Get everything EK!
Quack 🦆
https://linustechtips.com/topic/221330-first-build-water-cooled/#findComment-3035894
If you're hell bent on throwing a blocked 270x you may as well consider a used gtx 590/680/770 hydrocopper if you can hunt one down, most come with a lifetime warranty from EVGA and the block is already installed for you.
As for compression vs. barbed, compression, always compression. The only exception to that would be specialized fittings like stop/drain plugs, T-junctions, etc.
Brands, EK and Bitspower are all I will ever use again. Hated Monsoon, PrimoChill fittings are a joke (love their tubing though), and Enzotech's fittings leave something to be desired in the fit and finish department -although they do get the job done and they are cheap.
If this is your first loop just make sure none of the components contain aluminum and go with copper/acetal as much as possible. For the liquid itself I'm a big proponent of using something like Primochill's sysprep (flush the entire gallon) and use only distilled water (with another gallon flush before final fill). If you really want colored liquid in your loop as opposed to colored tubing make sure to read the warning messages on every marketed bottle, most will have a "use for a maximum of X months" prominently displayed somewhere and you can fully expect to have to flush a mountain of crap out of the system by that end date. Depending on the brand there may be staining/residue left behind, just make sure to do your research beforehand.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/221330-first-build-water-cooled/#findComment-3041817
awesome thanks i was originally going to do a aurora fill the read after a while it looses its touch and clogs everything i changed all the fittings i want to ek $90 all togother DX gg
https://linustechtips.com/topic/221330-first-build-water-cooled/#findComment-3041890
  • 2 weeks later...
ive changed it around abit so its a little bit more necessary for water cooing :)
I see that :o
Is the single 120x30mm rad a mistake? because that will not be enough...
For the 290x alone the minimum rad I would go with is a 240x45mm...add another one for the CPU, ideally you would have one 360x30 or 45 and an additional 240x45 (or 2 240x45's).
https://linustechtips.com/topic/221330-first-build-water-cooled/#findComment-3141956
Sounds like this is your first pc build as is and I would highly avoid WCing a setup for your first...
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/221330-first-build-water-cooled/#findComment-3145622
