Hi guys
I will be building my first PC for home use. I would like to know your thoughts and any recommendations you may have on the components I have selected.
Gigabyte GA-Z97X-SLI Intel Motherboard
Intel Core i5 4460 3.2 GHz 4th Gen CPU
Corsair Vengeance Black 8GB DDR 3 1600 MHz Dual channel
Crucial MX100 128 GB 2.5" SATA 6GB/s SSD only for OS
Corsair CS 550M Power Supply
Graphite Series 230T Windowed Compact Midi Tower Case
I have a 3TB HDD which will be used for everything but the OS and also a DVD RW drive
Im not too sure on motherboards so if someone can advise as to using this motherboard or a different one instead
Also the case comes with 3 preinstalled fans with support for up to 6, Would 3 fans be adequate for this setup?
Any advice and recommendations greatly appreciated
https://linustechtips.com/topic/221219-thoughts-on-my-pc-build/
budget?
use?
please read before posting http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/
quote me if you want some assistance
How to Post Topics, the Right Way / The Ultimate Build Parts List
"4 words. DON'T BE A DUMBASS" ~@Swndlr
https://linustechtips.com/topic/221219-thoughts-on-my-pc-build/#findComment-3032563
Sorry my bad
I am in the UK my budget is no more than £600 the components I have selected come to just over £500 so a little room for improvements. I will be using my PC for watching movies browsing the web, email, music etc. Only gaming it will be used for is online and will be hooked up to 1 monitor ( I use my TV as a monitor 1080p full HD)
I have both Windows 7 and 8, I will be installing windows 7
https://linustechtips.com/topic/221219-thoughts-on-my-pc-build/#findComment-3032780
