This is confusing me. Help please.
There are 3 consecutive even numbers. Five times the third integer plus the first integer equals 104. Find the second integer. Find the two consecutive numbers whose sum is 119
This is confusing the shit out of me. Thanks
https://linustechtips.com/topic/221077-math-help/
Here's an idea. Stop doing cocaine, Algernop.
QUOTE ME OR I PROBABLY WON'T SEE YOUR RESPONSE
My Setup:
Desktop
CPU: Ryzen 9 3900X  CPU Cooler: Noctua NH-D15  Motherboard: Asus Prime X370-PRO  RAM: 32GB Corsair Vengeance LPX DDR4 @3200MHz  GPU: EVGA RTX 2080 FTW3 ULTRA (+50 core +400 memory)  Storage: 1050GB Crucial MX300, 1TB Crucial MX500  PSU: EVGA Supernova 750 P2  Chassis: NZXT Noctis 450 White/Blue OS: Windows 10 Professional  Displays: Asus MG279Q FreeSync OC, LG 27GL850-B
Main Laptop:
Laptop: Sager NP 8678-S  CPU: Intel Core i7 6820HK @ 2.7GHz  RAM: 32GB DDR4 @ 2133MHz  GPU: GTX 980m 8GB  Storage: 250GB Samsung 850 EVO M.2 + 1TB Samsung 850 Pro + 1TB 7200RPM HGST HDD  OS: Windows 10 Pro  Chassis: Clevo P670RG  Audio: HyperX Cloud II Gunmetal, Audio Technica ATH-M50s, JBL Creature II
Thinkpad T420:
CPU: i5 2520M  RAM: 8GB DDR3  Storage: 275GB Crucial MX30
https://linustechtips.com/topic/221077-math-help/#findComment-3030604
i know
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
https://linustechtips.com/topic/221077-math-help/#findComment-3030611
If no one tells you in an hour. I'll tell you.
if he really doesnt figure it out by then...
dude, just write it down, using x, x+1, x+2...
https://linustechtips.com/topic/221077-math-help/#findComment-3030626
So do u just ignore the other shit?
https://linustechtips.com/topic/221077-math-help/#findComment-3030652
A 14
B 16
C 18
That's the 104 bit
May I ask how you got it?
https://linustechtips.com/topic/221077-math-help/#findComment-3030656
no, just use those as your numbers, then make equations with them, however the numbers in the assignment want...
https://linustechtips.com/topic/221077-math-help/#findComment-3030658
OHHH so like x+2•5+x=104?
https://linustechtips.com/topic/221077-math-help/#findComment-3030674
@Firearm2112
I'm European so bear with me. Use x, (x+2), (x+4) then write down these equations:
5(x+4) + x = 104    ----- 6x + 20 = 104   ------ x = 14  -------- Second integer = (x+2) = 14+2 = 16
Second question:
x + (x+1) = 119   -----  x = 59, (x+1) = 60
Hope this helps! :)
SimRacer - Casual FSX Pilot!
Mobo: MSI B550 Tomahawk | CPU: Ryzen R5 3600 | GPU: Vega 64 Sapphire Nitro | RAM: 16GB Crucial Ballistix DDR4 3200Mhz | PSU: EVGA P2 1000W 80Plus Platinum | Storage: 256GB Samsung 840 Pro SSD - 1TB WD Black - 2TB Seagate HDD | Cooling: Dark Rock Pro 3, Noiseblocker eLoop Fans | Case: Phanteks Enthoo Luxe | Audio: Sennheiser HD598 - JBL LSR305s | Display: BenQ EX3501R, Asus VG278H
https://linustechtips.com/topic/221077-math-help/#findComment-3030680
probably, i didnt check the numbers. but these kinds of assignments give you the way to solve them in the task itself
https://linustechtips.com/topic/221077-math-help/#findComment-3030683
@Firearm2112
Second question:
Hope this helps! :)
I sorta get it. Thanks man
https://linustechtips.com/topic/221077-math-help/#findComment-3030709
Hope I understood correctly, you're welcome. :)
https://linustechtips.com/topic/221077-math-help/#findComment-3030712
the one comment i have to say about this is that the usual (best?) way to represent an even number is 2x, so it should have been
1st number = 2x
2nd number = 2x + 2 = 2(x + 1)
3rd number = 2x + 4 = 2(x + 2)
then substitute in the given equation and you're done
https://linustechtips.com/topic/221077-math-help/#findComment-3030761
1st number = 2x
It's not necessary for this particular question though.
https://linustechtips.com/topic/221077-math-help/#findComment-3030789
yeah, but the exercise would serve no purpose by itself, its point is to be able to translate propositions into symbols, so i think it's best (and doesn't take much effort) to pay attention to these details
if the scope was to just get the solution of this particular problem you could use naive approaches like the one with a huge paint image in the previous posts, but good luck if you then have to work with more complex things and you're used to just go with "intelligent trial and error"
https://linustechtips.com/topic/221077-math-help/#findComment-3030821
I agree with you, it could be useful in long term but I've always used ''x'' and never had a problem.
dat pun
https://linustechtips.com/topic/221077-math-help/#findComment-3030850
