I am pretty sure my system is bottle necked by my CPU
  • i have a asus 770 direct cu oc 2gb
    kingston ssdnow 240gb 450mb read/write (games all ran on this )
    Amd am3+ socket asus sabertooth 990fx r2
    and a amd phenom x4 995 black edition 3.2ghz
    with 8 ggb of ddr 3 kingston memory
    and WD green 1tb drive for storage
    and a 500gb WD Green for storage
The main uses for this system is gaming i mainly play wow on ultra and i can dip down to like 5-10 fps at the start of boss pulls and usually maintain 40-60 fps other times.
Will i find better performance with not so cpu bases games?
I seem to have no issues with league of legends and minecraft or diablo 3
I am planning on getting a amd 9590 and a h100i for a cpu replacement sometime later this year
Thanks in advance
EDIT:
Im monitoring my load with Asus gpu tweak and ai suite II for my cpu
When gaming almost all 4 of my Cpu cores hit 70-80% load and my Gpu never really goes past 50-60%
I have heard that wow is a Almost all Cpu based game and a highend gpu has no real advantages
Edited by Lornedh
https://linustechtips.com/topic/220987-bottlenecked-or-not/
monitor GPU load with afterburner or any other GPU tool available if it's not 95% and up constantly then your cpu is holding you back in the game you are playing.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/220987-bottlenecked-or-not/#findComment-3029394
Yeah that cpu is a bit of a bottleneck. You could just get a new FX CPU and keep the same motherboard, that is a good board.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/220987-bottlenecked-or-not/#findComment-3029397
Sooo, the only issues is when you play WoW? Open the task manager when you play the game and after a frame drop alt - tab to see the % usage of your RAM & CPU. There is a bottleneck your your system, but not a huge one. These frame drops might be from the server or something (don't know..., never played wow)
https://linustechtips.com/topic/220987-bottlenecked-or-not/#findComment-3029424
yeah to be sure use gpuz and log to file while playing a game to see if it peaks at all. you can also monitor the cpu usage with something.... i think windows can do that if i'm not mistaken
CPU usage won't mean a lot unless it's pinned at 100% that would indicate a clear bottleneck...monitoring GPU load is a much better idea.
https://linustechtips.com/topic/220987-bottlenecked-or-not/#findComment-3029483
