CPU overclocking question
Go to solution Solved by Archangel1994,
Set the voltage to manual, put it on 1.3V then go as high as you can without bluescreening on a stress test like OCCT or aida64. When on the highest stable you can achieve, set to adaptive
ok, so i just started to overclock my G3258 and i am at 3.9Ghz. I have not changed any voltage settings yet; they are all on auto. Is this bad? My motherboard is the MSI H81M-P33. Its an h81 board, so obviously not designed to be overclocked with.
I downloaded HWinfo and the only cpu-related voltage i can see is the VID. Here's a screenshot.
Is this safe? am i doing anything wrong?
post-103118-0-49163200-1411499583_thumb.
Recovering Apple addict
ASUS Zephyrus G14 2022
CPU: AMD Ryzen 9 6900HS GPU: AMD r680M / RX 6700S RAM: 16GB DDR5
https://linustechtips.com/topic/220983-cpu-overclocking-question/
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
he means go high with the clock speed, not the voltage!
5.1GHz 4770k
My Specs
Intel i7-4770K @ 4.7GHz | Corsair H105 w/ SP120 | Asus Gene VI | 32GB Corsair Vengeance LP | 2x GTX 780Ti| Corsair 750D | OCZ Agility 3 | Samsung 840/850 | Sandisk SSD | 3TB WD RED | Seagate Barracuda 2TB | Corsair RM850 | ASUS PB278Q | SyncMaster 2370HD | SyncMaster P2450
Btw: what is the cpu ring voltage?
Also, how hot is it safe for the cpu to get? I am using the stock intel cpu roaster, so I just want to make sure I don't get too hot.
generally its not advised to OC on stock cooler. You would want to get yourself a decent air cooler like an evo 212 which is about $35 best for the price.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
generally its not advertised to OC on stock cooler. You would want to get yourself a decent air cooler like an evo 212 which is about $35 best for the price.
Yeah, i know, but im sitting at 80C under full load running IntelBurnTest OCed to 4.5Ghz @1.220v. Gotta remember this is with a pentium G3258. its only got 2 cores. ;)
Edit: make that 1.23v. just crashed... :(
You must be living in an ice box to keep your CPU at 80c OC'd like that...
Community Standards
"Beast Mode"
No, ambient temps are about 75ish generally(Fahrenheit). It goes down in the winter and up in the summer ofc, but the average is probably close to 75F. :)
