Issues
Go to solution Solved by scaryjam823,
Ah that explains alot.... THANKS! :D Hmm so it still is better to have the top front fan as exhaust right? :P
Hmmm is my case airflow good enough for crossfire 290x?
Yes sir. If you change the fan you would have to change every one to accommodate the different air flow. I've had mine configured this way for 10 months every since I built my rig and my case temps never get about 28c, graphics card around 75c and cpu at 60c. It's a good config. :)
Hey guys! I just wanna ask, is it better for me to put my 212x horizontally? I only feel hot air coming out of the rear exhaust the the exhaust fan at top nearer to the rear but not the top exhaust fan nearer to the front? (I cant really flip the SP120 at the top exhaust (nearer to the front) as the rubber parts of the fan got absolutely destroyed by the god darn shop owner i went to) Any suggestions?
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/220676-issues/
I would mount it exactly how you have it shown given your fan config. (with the fan blowing towards rear exhaust.)
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/220676-issues/#findComment-3025149
You can mount it either way. There will be little to no difference temp wise which way you do it. The important thing is to get the hot air out as easily as possible.
Corsair 750D | Asus Crosshair V Formula-Z | FX 9590 | Kingston HyperX 16GB@1866MHz | MSI R9 290X Lightning | Seasonic 1050W Platinum | 2x WD 3TB Green HDD | Samsung 840 Pro 256GB SSD | Crucial 512GB SSD
Alphacool XT45 360mm | Alphacool Monsta 280mm | Silverstone AP121 | Silverstone AP141 | EK Supremacy Elite | EK ASUS C5F-Z | EK R9-290X Lightning | EK 3/8-1/2 Nickel | XSPC D5 Acrylic Tank | Primochill 3/8-1/2
https://linustechtips.com/topic/220676-issues/#findComment-3025157
But the problem is i dont feel any hot air coming out from the top sp120 exhaust (nearer to the front)
Turn the EVO and see how it fares?
but wont the hotair from the GPU pass through the heatsink... D: (i feel like i am not utilising one of my sp120)
https://linustechtips.com/topic/220676-issues/#findComment-3025163
It probably already is..
https://linustechtips.com/topic/220676-issues/#findComment-3025164
What if i were to add a 2nd 290x D: Would there be any difference?
https://linustechtips.com/topic/220676-issues/#findComment-3025168
Hmmm true that....  So which would you recommend? horizontal or vertical? D:
https://linustechtips.com/topic/220676-issues/#findComment-3025171
That's because there isn't anything hot on that side of the case. All the hot air is being blown to the back side, it's exactly how my fan config is and I only feel hot air from the top rear fan. The front top fan is pulling air upwards so your cpu cooler and rear exhaust can then pull it out of the case with ease.
air in from the bottom half of the case getting pulled to the top half of the case by your top front fan. Then the rear fan is pulling that air farther towards the top rear of the case where it finally gets exhausted either at the rear or the top rear.
My fan config is the same way
https://linustechtips.com/topic/220676-issues/#findComment-3025190
Even if you dont 'feel' it, there still is warm air coming out of the system as a whole not just the cpu cooler.
Maybe a little difference in temps but you have ample air flow from the bottom and front sides of your case. The temps will rise because there is another heat producing item in there but the temps wont get up to a point were you have to worry about it.
https://linustechtips.com/topic/220676-issues/#findComment-3025191
https://linustechtips.com/topic/220676-issues/#findComment-3025214
https://linustechtips.com/topic/220676-issues/#findComment-3025237
ah thank you :)
https://linustechtips.com/topic/220676-issues/#findComment-3025255
