Hey guys, got a problem and i hope someone could guide me to that light at the end of the tunel aka the fixe
So, ive started playing this new mmo that launched like a week go and im getting terrible drops in fps even tho i got better specs then the recommended specs.
My specs are
i5 3,3 gzh cpu
asrock h81m-dgs
gainward geforce gtx 650 Ti 1GB
6 GB RAM
500 W PSU
300 something Harddrive ( cant remember the make and model since its from my old pc)
WD external drive 500GB ( thats just for storing stuff like files i dont use alot and stuff)
Recommended specs for the game are
intel i5
nvidia GTS250 1GB
4Gb ram
40 GB storage
i dont run the game on ultra settiings tho, custom settings a few on high rest on medium and i get 60 fps but some times like getting in a place with alot of people or even on a map with few people that fps drops to 1-6 and its just so annoying that the gameplay just isnt fun for me anymore.
So after all this text, what im asking is, should i get a SSD? Or does my build need upgrades ( take in mind i dont really have a budget yet just wanna know the path i need to take)
Thanks.
https://linustechtips.com/topic/220638-annoying-drop-in-fps/
you would be dropping fps due to your GPU everything else should be fine for the moment if u don't have the money to upgrade.... also  don't run the game at ultra if your GPU can't handle it
Yes Yes Legalize Gay Marriage sure, but have you ever considered Weaponizing Gay?
CPU: I5 4690 3.5ghz || MOBO: MSI B85-G43 Gaming Board || RAM: 8GB Corsair Vengance Pro - Red || GPU: Gainward GTX770 Phantom 4gb || PSU: EVGA SuperNova 750W Gold || Case: Thermaltake Urban T31 || SSD: Corsair Force 120GB || HDD: 1TB WD Black
https://linustechtips.com/topic/220638-annoying-drop-in-fps/#findComment-3024669
im running the game with customs settings, 2 or 3 at high rest at medium.
https://linustechtips.com/topic/220638-annoying-drop-in-fps/#findComment-3024725
Massive multiplayer Online role playing games are notorious for having massive frame drops when multiple avatars are on screen its generally caused by a CPU bottleneck.
you can confirm this by running a gpu monitoring tool and watch its usage if the usage is not at 100/99% then your cpu is bottle necking the card and the only solutions are to overclock the chip, get a stronger one or lower settings such as draw distance or Level of detail settings.
https://linustechtips.com/topic/220638-annoying-drop-in-fps/#findComment-3024767
Any sugestion on what monitoring tool should i use?
https://linustechtips.com/topic/220638-annoying-drop-in-fps/#findComment-3024982
MSI afterburner, EVGA precision X (preferred), Gpu-z will all work
Forgot to also mention that my pc laggs like after alt tab-ing the game to check something on my browser it like freezes or takes along time to minimize or maximize the browers window
EDIT: GPU runs at 99% usage while ingame
https://linustechtips.com/topic/220638-annoying-drop-in-fps/#findComment-3025035
