I just just a new phone and im trying to clean my iphone 4 but i cant get the icloud account password right, i reset the password around 5 times and still nothing.
\/Specs\/
Xeon E3 1230 V3-Maximus vi hero-2x4gb G skill RipjawsX 2133-EVGA supernova-1 tb seagate-Samsung 840 EVO 1TB-NZXT H440-EVGA 6Gb 780 Razer-Blackwidow Ultimate-Corsair M65
MSI Ghost Pro GS60
https://linustechtips.com/topic/220572-icloud-problems/
A hacker stole your nudes sorry...
https://linustechtips.com/topic/220572-icloud-problems/#findComment-3023625
Do a factory reset through itunes
MOBO: ASUS X79 Pro CPU: i7 3820 Ram: Corsair Vengence 32Gb 2133mhz (8x4) GPU: 2 x Sapphire R9 290 in X-fire PSU: Seasonic G series 750w Drives: 1 x 750 gig WD black, 3x WD Black 1TB, 1 x Segate Barrcuda 1 TB, 1 x Toshiba 2TB, Intel 520 240gig SSD Case: Enthoo Primo w/ Green and Blue LED lighting.
https://linustechtips.com/topic/220572-icloud-problems/#findComment-3023633
lol does that mean im famous now?
it says i need to turn off "find my iphone" and i dont know the icloud password for that account.
\/Specs\/
MSI Ghost Pro GS60
https://linustechtips.com/topic/220572-icloud-problems/#findComment-3023679
Well, why would you not know...? If you reset it? Are you sure you are using the right account? Also, should I post this on the Apple Support Forum for you, because they are usually much better at solving these things...
Owner of a top of the line 13" MacBook Pro with Retina Display (Dual Boot OS X El Capitan & Win 10):
Core i7-4558U @ 3.2GHz II Intel Iris @ 1200MHz II 1TB Apple/Samsung SSD II 16 GB RAM @ 1600MHz
https://linustechtips.com/topic/220572-icloud-problems/#findComment-3023817
load iTunes, turn off your phone. Press and hold the home button, power on the phone, it should say something about factory in iTunes, hit ok, and the phone should start the process of a factory reset. Easy done
https://linustechtips.com/topic/220572-icloud-problems/#findComment-3024610
